Clearcorners.com DOES NOT sell this conversion as a kit. In fact, they state on the website that they refuse to do so. I fabricated everything myself after doing tons of research on the parts, overall design, and fabrication. It wasn't easy and it was really expensive but it was SOOO worth it!i2ice4m3 wrote:that looks VERY nice. did you get that kit from clear corners, or put it together yourself?
It can't be much worse than stock. Like you said pop-up lights. I want to try a fixed head light set-up and don't want to do the silvia front end even though it is so sweet.InsanityInc wrote:only problem is, it'll fall apart if you go fast enough with your lights on. Can't be doing wonders for your aerodynamics, either.
