opie240 »
https://forums.nicoclub.com/opie240-u191787.html
Thu Oct 06, 2011 9:03 am
I am currently dealing with the same issue, except my seatbelts quit working as well. Check the fuse (bottom left, 2nd up) for continuity to ground with the key off. That's what my issue is but I loose ground when key is on, this is not a ground wire either. Could be a totally different issue but its a start. I'm sure I will be corrected if I am wrong but, i believe the grounds for these relays are in the engine bay, behind the driver headlight, on the fender. Happy Hunting.
