s13 power window regulatorrr
x3rikaa
is there any place i can buy one that is BRAND NEW? ive tried searching online but they only have ones for '14s -_- and ONLY window motors for '13s. :\ i dont wanna use a second hand one, id rather put in a new unit. yennooo? so please can some one lmk the hookups :]
thompsn
Car: '93 s13 coupe
If that goes bad, will the window not go up and down?
I'm trying to figure out what's wrong with mine, I can hear it click
when I press the switch but nothing happens.
Shabbernigdo
yes if your regulator dies then your window will not work.
I had the same problem on mine. it turned out that some of the solder had broken off the terminal and it was no longer making the connection so all i had to do was resolder it and it worked like new.
a s14 unit will work in an s13
To the op there is nothing wrong with a second hand regulator.
There pretty well built and last a very long time also a used one is like 1/5th the cost of a new one
