s13 power window conversion
datsunzsxman7393
Car: 1993 240sx Fastback
1973 240Z
Im in the process of doing a manual to power window conversion on my 93 hatchback. I already ran the necessary wiring to each door, and i have the door harnesses for both sides. My question is, is the power window amp necessary to use/wire? What is it's function? I don't see the need for it, I would simply run the power to my driver side switch, then directly to the motor, and vice versa with the other side.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
Your windows wont work without it
240srCoupe
Car: 91 240SX SR powered, S13 Silvia triple projector front
Are you changing the entire door for power doors or just the "guts"?? I did this swap in an 89 coupe but had a set of power doors and just did the other wiring inside the car and everything works perfectly, I forget what was missing inside as far as all that went but it works perfectly...I would have to go back and retrace my steps though because its been forever since I did my swap.
