240sxFTW »
https://forums.nicoclub.com/240sxftw-u122505.html
Sat Aug 08, 2009 9:59 pm
So the cable thats attached to the motor on my passenger side window snapped causing the window to fall into the door but it didnt break thankfully. So i read on a few threads and i heard you cant just replace or re-attach the cable you have to buy either a whole new motor or just the regulator. I have also heard that you need both. So my question is what part do i need?
and also there is not much room at all to look around inside that power window assembly once the door panel is off. is there an easier way to replace the assembly? or am i gonna have to slide it in, and wiggle it around until i find the right spot ( )
