s13 power issues
crash n' burn
Car: 93' coupe
swapped out the chassis harness from a coupe with the exact options as mine had to complete the auto to 5spd swap. i wanted a true 5spd car..no starting the car w/o the clutch, enjoy my reverse lights, etc etc..
so there i am..putting my interior in for the last time; you know..super f*** excited and all. i've got all my wiring for gauges EBC, TT, fans, all that jazz buttoned up on. turn the key........no pwr windows, no sunroof, no door chime, no cluster lighting(speedo, e-brake, open door light and clock come on), no running lights, no tail lights, no turn signals. everything else is good.
now i don't have my engine harness hooked up, but that shouldn't bother any normal operations? checked my fuses, checked the fusible links, relays is a guess, opened up the turn-signal stalk and checked the brass contacts, changed out the TCU..that didn't work, so i opened them both up and checked the circuit boards. I don't know wtf is going on, i checked the ohms on the grounding points w/ neg. terminal, made sure i was getting voltage to the relay boxes and the ignition cylinder, etc etc. there is no reason why it shouldn't be working.
ERMAHGERD :facepalm: ..i need help
crash n' burn
Car: 93' coupe
also..my dash is not installed, so the dash buttons and everything aren't plugged in..not having my dimmer switch plugged in wouldn't cause this would it?
