s13 popup headlight reset
mshackl3
Car: 93 240sx
I just got a new motor for my 93 and I can't get them to line up and I have adjusted the motor and the linkage can anyone help ?
Modified by mshackl3 at 1:41 PM 1/16/2009
Modified by mshackl3 at 2:15 PM 1/16/2009
Taylor008
Car: 240sx Coupe
You need to be more specific. I THINK you're asking how to line them up with the body lines.
To do that, pop the hood and loosen the bolts holding the headlight to the body, don't take them off, but just loosen so you can wiggle it a little. There is also another bolt under the headlight (behind the bumper) that attaches to the body as well. Loosen those and line it up the way you want, then tighten them.
mshackl3
Car: 93 240sx
The new headlight motor we put in will not adjust to the right height even after adjusting the motor knob and the linkage arm, when the lights are off I have the one headlight closed and the other headlight with the new motor about 3 inches off fully closed position.
Modified by mshackl3 at 3:12 PM 1/16/2009
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
you can manually crank it down to get it to the closed position.Then it will be matched up to the other side.
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
^dude your sig is ridiculous
SirSilvia
Car: Sold both my babies
what about where the linkage arm bolts to the motor's output shaft? if its in the wrong position then it won't shut right now matter how you adjust the linkage in the middle.
mshackl3
Car: 93 240sx
we have done that then when I turn lights back on it just resets to the almost sleepy eye look it is pretty aggrivating lol,.
mshackl3
Car: 93 240sx
ok thanks I will try some adjusting with the linkage arm tomorrow thank you, by turning on and of the motor and adjust it like that.
driftneil
Car: A pile of cars.
You have to loosen the arm bolt, and move it how much its offset now. Then tighten it and see if its ok, if not adjust as needed. Took me bout an hour to get perfect. Have fun!
