S13 passenger side door panel
JonnyB4Real
how do I get it off, Ive searched and searched and all I can find is how to take off the drivers side. I have done all the steps to get the drivers side off but the oh **** bar is still holding it on. I cant figure it out help me please :help
bcar240
Car: 1993 240SX HB
it is almost the same as the drivers door, you just have to remove the hand hold also. there is a screw at the top of the hand hold that you take out then you have to rotate the handle (90 degrees I think) and the bottom will come free.
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
yep. there is a screw hidden by a cover at the upper left-hand corner of the panel that needs to come out. twist the hand-hold 90* and then pull up. there is one in the hand-hold and in the window switch pocket, covered by a plastic cover. take those out and then just slide you hand under the door panel and pop the clips loose. then remove the panel. thats it. :)
