S13 Pads problem
dlp
Car: '93 200sx CA18DET
Hello guys
I've problems looking for pads for my S13 200sx (CA18DET).
It seems to be differences between brakes for USA and non-USA S13
1- NON-USAFront: CL25VA Pad length x width x thickness (mm): 134.1 x 45.3 x 11.0Rotor Outer diameter x tickness (mm): 257 x 22
Rear: AD9Pad length x width x thickness (mm): 93.8 x 33.4 x 10.0Rotor Outer diameter x tickness (mm): 266 x 9
2 - USAFront: CL18VBPad length x width x thickness (mm): 100.8 X 44.3 X 10.0Rotor Outer diameter x tickness (mm): 250 X 18
Rear: CL9HPad length x width x thickness (mm): 75.0 X 40.0 X 9.5Rotor Outer diameter x tickness (mm): 258 X 9
as you know, is it right?
At most sellers, HB231N.625 is the common pad for 240SX in USA, it seems to be the wrong one for me (assuming that the common option is for usa s13). The other one listed is HB235N.665, it is listed in some sites as 240sx or G20 Infinity front pad, it seams to be the right one (since G20 & P11 have the same front brake CL25VA). But i'm not sure.
So, my problem is how to know "a priori" what pad are for my brakes. Also i don't know if the HB262N.540 fits rear calipers.
Help me please, i need to know this before buy, i live at Chile and return anything back to the provider is not an option.
ThanksCheers
dlp
anyone? please...
loonx
hmm interesting..
xorro
Car: 92 nissan 240sx convertible
wouldnt be the pads for the abs installed s13 i would think they re near match?
dlp
what's the disk diameter for ABS USA S13 front disk?
i think them fit in my non-ABS non-usa S13... lol
or?
or?
cheers
