i agree, but dollar for dollar coilovers are going to be more beneficial in the long run vs a sway bar and stock suspension, or just with lowering springs.
E7-S14 wrote:excuse my ultra newbishness herebut by alignment.. you mean?.. make sure the front tires are aligned?..cuz i didn't think so
thx..
you are thinking of an alignment like a normal person would. thats wrong lol.
out of the factory your car is designed with safety in mind, NOT with performance. therefore it runs a very passive alignment that is more focused on tire wear and keeping you out of trouble (understeer biased)
as soon as you get coilovers you should start considering doing a TRACK orientated alignment (more camber, more caster, LESS toe). whats the difference? the car will then handle 10x better, and be more predictable, and easier to initiate, and go faster, and bla bla bla.
a good alignment made as much of a difference as good coilovers did to my car.
my current setup
.1d toe in front AND rear
2.5 camber front and rear
8.5 caster front.
subtle changes to your alignment can completely change the way your car handles ONCE YOU UNDERSTAND HOW IT WORKS AND HOW IT FEELS. DONT d!ck WITH IT TILL YOU ARE CONFIDENT AS A DRIVER. i cant stress that enough.
i used to run toe out in the back (.1-.2d). that gives snappier initiations but is slower and less controllable at speeds. changing to toe in made it harder to initiate, but the car just sticks to the ground better while drifting.
