s13 or s14 sr20det???
NickWendt03
Car: 95 240
Hello yes im a newbe sorry but I had to start somewhere. I have searched NICO for probably 6 months now but have never posted. My cars pretty much stock and I have been saving ever since I bought it. By the end of the summer ill have around $4000. I wanted to know in your opinion since a lot of you have a lot more experience than I do with this motor if I should lean towards the s13 or s14 sr20det. I know all the stock facts about each motor from searching this site, but I see a lot more s13 swaps than s14 is that because they're less expensive or is there something I don't know. I can get the motors from a near by shop http://www.zerolift.com/($1650 for the s13, and $2500 for the s14 both come with engine, ECU, and transmission. Im leaning towards the s14 motor but that extra $850 if I go with the s13 motor looks good to.
Any replies would be appreciated and sorry if this is a typical newbe question that I couldn’t find while searching. Fell free to flame me, I got to learn some way.
ca18det_boy
S14 head is a better design and its more expensive. S13 still good but its a high port head. Just depends on how much you wanna spend. Personally I think more people go for the S13 because its cheaper.
Nismo_Freak
Car: 89 Nissan 240SX
S13 motor.
Florida240sx
Yea I say S13.You going to install yourself?
NickWendt03
Car: 95 240
yea i think i can do it myself because the $1200 they want for install i think is a little steep.
S14owner95
Car: 95 240SX, S14SR, JIC Suspension, Mad Tyte Stickers
S14 Motor.. just because the slant is SEXY.. but the only problem you run into is tuning with an S-AFC.. which I found out about yesterday.. because the 14 ECU is so aggressive when you start to run higher boost you need more timing, and it throws all kinds of weird signlas between the ecu and the SAFC.. I hear that the 14 ECU is harmless.. you can play with that thing all day.. but I think for the money.. only 850 more.. get the 14..
starscream6
Car: 93 civic/B18c
if you bought the s13 sr and upgraded the turbo to the t28 would that the about the same as the s14 sr? how much does the t28 go for?
NickWendt03
Car: 95 240
starscream6 wrote:if you bought the s13 sr and upgraded the turbo to the t28 would that the about the same as the s14 sr? how much does the t28 go for?
good point check this out http://cgi.ebay.com/ebaymotors...=WDVW might just have to do that.
ca18det_boy
no the 14 has the vvt to help the turbo spool faster.
Morph
Car: 91 Sr Powered Coupe
If you get a motor from there make sure that you pick it out and have a compression test and all of the other **** done before you buy it. If you have an s13 get the s13 motor if you have an s14 get the s14 motor. An s14 into an s13 has a little more pita than just a s13 into and s13.
P.S. make sure u get an mafs and ignitor chip if you get it from there.
Turb0wned
s13 motors will make more power in the end...s14 motors are to much more money for barly anything wow u get a t28 which is still to small for me and that vvt not worth the extra money in my opinon
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
ca18det_boy wrote:S14 head is a better design and its more expensive. S13 still good but its a high port head. Just depends on how much you wanna spend. Personally I think more people go for the S13 because its cheaper.
Highport has more power potential.
S14 pro's:-newer-VTC-T28 turbo
S14 con's:-more $-VTC-lowport head-harder wiring
VSJA1725
Car: 91 Nissan 240SX (hatch)
the VTC is both a pro and con>? ME not get
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
It really depends on what power level you are going for. If you want all out power, go with the Highport s-13 motor, If you only want <300 hp with basic bolt ons you could go with the slighly newer s-14 for the mileage factor (this is what phase 2 suggested by the way).
