DALAZ_68 wrote:u want less headaches stick with an s13 DOHC
its a straight drop in motor all u need is the DOHC engine harness...
if u go S14 form 96+98 even some 95 (late models) u have to change a **** load distributertemp sensorthrttle body
etc
a bunch of crap...
just stick with a dohc from s13
ur gonna need the DOHC ign module and coil...if u need it email me i have mine left over from my old DOHC swap
actually its not that bad, yes you do have to change your distributor, and all of that other stuff. the easiest way to do it is just sit the motors side by side, strip down the s14 motor (pretty much take the manifolds off), and then transfer everything off of your s13 motor onto it, flywheel can stay from the s14, but be sure that your remove and transfer all of the smart parts. i just did this on mine, i have 91 s13 that i bought with a blown head gasket, found a 98 motor with 67k miles on it for 250. took me like 30 minutes to transfer everything over. so don't be scared to throw and s14 motor into your s13!
