crash n burn »
https://forums.nicoclub.com/crash-n-burn-u49621.html
Mon Dec 17, 2007 7:22 pm
now i was led to believe the TT diff housing was longer at the pinion (i have no idea what its called, the "front") where driveshaft flange is, by almost 2 inches or so. cant forget that its set up for highway, so it has some pretty weird gear numbers 3.692?. the n/a ones have 4.083? the exact same gearing either way. but if you have a 6-bolt rear end like most s13's have, you'll need to source 5-bolt axles, or find j-30 ones since they bolt up to?
i dunno if im wrong, somebody correct me if i am, i may be
