Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Thu May 01, 2003 7:50 pm
"what else do I need to know before deciding rim sizes." how to use the offset calculator in the FAQ.
you cant use a 235 for the front of a 17" rim, the tire is too wide. try a 17x7.5 in a 28mm 0ffset, or run a 225 on a 7" wide front wheel. you can run upto a 8-8.5" rear wheel in a 255-35-18 for the rear, about a 33-35mm offset *should* clear. please use all the information in the FAQ, you could have figured all this out for yourself.-chet
