S13 not starting
ta_ma3750
Car: 1990 s13
i relocated my battery to my trunk and then when i went to start it nothing happend so i diconnected everything and put it back to stock and hooked a jump box up to it and then it would only try to crank and then it would just click and not start. then i got it to start so i took the jump box off then it just died and from then on i couldnt even get it to crank or start if anyone has any ideas as to what it could be please let me know
Schmitz_7
Car: 1990 Subaru Legacy Wagon Touring Edition, Mitsu Elclipse 2003 GS, 240SX Nissan 1990, 2001 Hyundai El
It sounds like you either blew something... flat out killed your battery or you didnt hook up/ ground your wires correctly. Double check everything.
ta_ma3750
Car: 1990 s13
yeah i had a bad ground, one of the bolts got crossthreaded so i had thought it was completey tightened down when in fact it wasnt, thanks for the heads up
Schmitz_7
No problem, Glad to be of Help.
