S13: New cluster, fuel gauge needle doesn't move
Zushi
I just replaced my SOHC digital cluster with a DOHC analog cluster. When I turn the key, the fuel gauge doesn't move. When I removed my SOHC cluster the gauge was just under half full. The DOHC cluster I installed was at 3/4 full. I have two DOHC clusters that I can test with (and I know they both work) and they both don't move. The second cluster is at 1/4 full and just sits at 1/4 when I turn the key. Do I need to "reset" the fuel gauge or what? btw, I am using a DOHC analog sub harness. thanks in advance.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Maybe the fuel sender units are different between models, and have a different output voltage to the gauge?
Or the wiring is screwed up somewhere?
Use a multimeter to check if you are getting any voltage to the plug that clips on to the gauge.
Cgeigert
Car: 1989 Nissan 240sx
As far as gas gauge all ka24e ka24de and sr20det gas gauges are interchangeable.
