S13 Motor Mounts!
ElNegroParaguayo
Car: 1990 Nissan 240SX SE Fastback
I need some info on DIY motor mount change. Shops wanna charge me 500 bucks...please help! i got an engine lift available i just need some tips on how to replace them. All 3 are being replaced..transmission mount and both engine mounts.thanks!
superbraut
im not a nissan mechanic, but i can tell you how i changed my mounts. I used the nismo motor mounts.
The process in which i changed them was , remove the bottom motor mount nut to one side only ( note this one is reallllly tough to take off. Make sure you have deeep sockets if you're using a ratcheting wrench. )
then remove the top nut of the motor mount. Leave the other mount's nuts broken loose but not removed completely.
After you have the nuts removed, jack up the engine however you wish ( i used a jack with a wide peice of plywood, jacked the engine up from the oil pan).
Remove the mount and place the new one in.
Lower the engine a bit untill the engine is sitting on the mount.
Tighten the nuts, and now repeat the process for the other mount.
I havnt done transmission mounts my self, but it seems a hell of a lot easier than motor mounts. I would have the transmission jacked up, so you can remove the cross member and transmission mount. Put the new mount on and youre done.
hope this helps
ElNegroParaguayo
Thanks alot!Did you have to jack up he car first or can you reach it without?Would it help if i remove the front wheels?
superbraut
YUp you gotta jack up the front of the car, remove the wheels. Always make sure your car is stable before going under. Use wheel chocks for the rear wheels.
vancouverbc
Car: 1991 240sx
ElNegroParaguayo
thanks! really helped out!my mounts are now done..now to the next issue..haha..gas tank leak..
