catnipple wrote:thanks for the reply.. i just dont know what pm is.. lol sorry im a newb!!
so ill need to get the s13 5speed pedals then? my s13 was an auto.. n ill check out the link now. thanksOutToWinPAHC wrote:I did this swap about 7 years ago first using a TH350 then to a T56. I dont know why your concerned with pedal, you can use the OEM pedals. All you have to do is make a throttle cable bracket ( you can now buy these too). For the master cylinder you want to use an aftermarket. When I swapped to T56 I used the Daft Innovations CMC kit and line. You will need to trim the ears off the transmission and smash that tunnel. IF you o not take the ears off you will hear the engines rotation in the cab of the car and it sucks. If you can fab you can make your own mounts, I like what I see there. I would also look into the Holden Monero oil pan baffles that are not supplied with the GTO pans.... and New Mexico.... yea your gonna wanna do what I did when it came to cooling it .
post4977785.html#p4977785
