S14toRPS13 wrote:I got eibach sportlines. It's not much of a drop but if you all you want is about a 1.5 drop. Then they should suit you. I got them for 215 from a local shop.
Sportlines lower more than 1.5", they lower 2.2' front and 1.75' rear. Lowering more than 1.5' will definitely affect his stock alignment settings. They're also crappy springs (my opinion--i used to run them before). Pro-kit is a safer bet but I believe their drop rates are less than 1.5."
The Suspension FAQ is here for spring rates and lowering rates.
zerothread/11638
