bias »
https://forums.nicoclub.com/bias-u49508.html
Fri Jul 27, 2007 3:07 am
When I did it gas did come out from the line when it was removed. I use a soda bottle to catch it until it was done. I'm not sure if it did it because of pressure in the line or because it was gas in the tank. Just look under the rear passenger side. The gas tank is sitting there under the car look in front of the gas tank and you should see the lines going to it. maybe you can tell from there witch one has been leaking. You will have to remove it from there as well as in the trunk once you remove the cover leading to your fuel pump.
