S13 kouki tail light wiring
abunai the drifter
Car: sileighty
I just baught some kouki tail lites for me s13 and I need help with the wiring if any one has done it and can please help
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
I've done it but umm i don't really remember.. It was easy thg just pair the wires they're the same color i believe. I can take some pics if you want me to ..
gumby74
I just did a search and found nothing useful, so I will not waste your time with that nonsense.Here is what I did; you will need wire cutters, preferably heat shrink tubing and a soldering iron.The wire colors are going to match from the kouki lights to the stockers, but the new lights run thicker wiring with bigger connectors.Remove the wiring from the stock lights. Cut off the connectors leaving a couple of inches of wiring to solder.Now, cut the connectors off your shiny, expensive new lights.Solder the stock connector onto the kouki wiring. Seal the connection with the heat shrink tubing or if you must, electrical tape.Do one side at a time, and simply match the colors. Also don't forget about the reverse lights in the middle.
abunai the drifter
Car: sileighty
leonelrr wrote:I've done it but umm i don't really remember.. It was easy thg just pair the wires they're the same color i believe. I can take some pics if you want me to ..
that would be awsome could you send them to my E-mail [email protected]
