s13 kade-s14kade questions turbo related
EazyBreazy
are there any differences in the s13ka and s14ka block and head other than the cams....im in the process of rebuilding a s13block for kat and i just wanna know for sure if there are any differences. obd anything doesnt matter to me cause its taged in ms where we have no emisions anything.. also where do you guys tap in for your oil supply to the turbo...is this any different on the s13 block than the s14 block
if this needs to be moved feel free to do so just tell me where it went
Structure240sx
use a T where the oil pressure sensor is next to the oil filter for the oil feed. i cant think of a single difference in jsut the head and block between the s13 and s14 other than the cams. small things like the valve cover bolts but that wont make a difference for you.
bbandit
it will work.. i plan on swapping my 91 block with lesser mielage 95 block this spring break
pearlwhite95
Car: work,my whip and my marine fish
would a dohc head work on a sohc? cause my freind has the sohc and was just wondering cause he needs to replace his!
Structure240sx
check out smug510's post in the ka24e & ka24de forum. it can fit with some mino mods but certain years will cause a very high compression ratio
