s13 ka24e to s14 ka24de HELP!!!!!!
s13ka24det
Car: Supercharge Eclipse Gt. S13 240SX ka24det,S13 SR20DET
i thinking about taking my 89 ka24e engine out, and puting a 95 ka24de. But i need help on the wiring, any help?????? i converting auto to a 5 speed. but i really need out on the wiring any help will be nice!!!!!!!
Tx-Sx-FS
Car: S13 KA-T
as long as you have the manual wiring for the 95 ka24de, and lower engine harness (battery/starter/alt) for manual..it will plug and play. and have the manual ecu, then parts the do the manual swap. its not all that difficult.
koukiKA240
Car: 1991 240sx KA-T
ummm not so much that easy. Better off finding a s13 DE enigne/harness/ecu. THEN the engine is plug and play and all you have to do is chase wires for the dash and gauge cluster. Its a monster cluster **** if you do S14.~SaM
mirra32
95 swap is exactly the same...i have installed two 95 motors in a 90 240sx....you need the distributer, ecu, wiring harness, MAF from a 91-94 240sx...plug and play the only cutting you have to do is cut the last plug right next to the ecu plug(stick out by itself) from you old e motor and splice that to you new 91-93 240sx wiring harness..i just made a custom exhaust to fit this....Headers back.....
