I want to turbo my S13 KA24DE with the S15 T28R BB Turbo
http://www.thenismoshop.com/ik...d=341
Here are my setups, and I have the following questions.
Oil Feed:
NISsport Oil Pressure Adapter for 240SX 1/8 BSPT (male & female) & 3 1/8 NPThttp://
www.nissport.com/catalo...tions
Steel -3 AN to 1/8 NPT 961603http://
www.anplumbing.com/shop...Steel
36" -3AN Line 63010136http://
www.anplumbing.com/shop...-Flex
0.03 Oil Restriction Inlet Fitting Turbo Restrictor GT28/GT28RS/GT30R/GT35R. Output is -3 AN male OILRESTAK2http://
www.takamotorsports.com/
I will get the oil feed from the stock oil pressure sending unit. Since the NISsport Oil Pressure Adapter has 3 1/8 NPT connections, I will use 1 for oil turbo line, 1 for oil temp sending unit, and 1 for oil pressure sending unit.
White 7 Color Oil Temperature Gaugehttp://www.glowshiftdirect.com....aspx
White 7 Color Oil Pressure Gaugehttp://www.glowshiftdirect.com....aspx
Reference:
zerothread?id=312476http://forums.nicoc ... ead/276957
Oil Return 1:
TunerToys 50.8mm Drain Flange 1/2 NPT: $16 (44mm = T25(S13) / T28(S14) | 50.8mm = GT28R(S15))
http://www.tunertoys.com/Tuner...k.htm
Gardner Westcott 1/2 NPT to 5/8 Barbhttp://
www.summitracing.com/pa...w=sku
Black Hose 5/8http://
www.anplumbing.com/shop..._Hose
Oil Return 2:
Swivel-Seal 90 deg. Tube Hose End -10AN 809110http://
www.anplumbing.com/shop...-Seal
Swivel-Seal Straight Hose End -10AN 800110http://
981610 Straight, Pipe Thread To A.N. Adapter 1/2 to -10ANhttp://
www.anplumbing.com/shop...minum
967110 Steel Weld Fitting -10ANhttp://
www.anplumbing.com/shop...!_Ons
400100 Premium Racing Hose. THE BEST! Use Swivel Seal or Auto-Fit Hose Ends -10AN 1-foot (QTY: 2)
http://www.anplumbing.com/shop...-Flex
GT Turbo Oil Return Flange w/ -10 AN Fittinghttp://himni-racing.com/index....vnp77
Reference:
zerothread?id=140446https://www.dwperfo ... m/...t=100
1) What is your preference between Oil return 1 and oil return 2 setups? Any other alternatives? Oil return 1 setup is cheaper but oil return 2 setup seems more reliable.
Oil cooler:
GReddy Oil Cooler Adaptor W/Thermostat 12401123http://
www.240sxmotoring.com/groilcoadw.html
"-10 AN Male to 1/2 in. NPT Male adapter fittings RUS-660500 (Quantity: 2) $3.95 each" (QTY: 2)
http://www.summitracing.com/parts/RUS-660500/
"-10 AN Hose to Female -10 AN straight hose ends RUS-610040 (Quantity: 2) $9.95 each" (QTY: 2)
http://www.summitracing.com/parts/RUS-610040/
"-10 AN Hose to Female -10 AN 90 Degree hose ends RUS-610180 (Quantity: 2) $21.95 each" (QTY: 2)
http://www.summitracing.com/parts/RUS-610180/
"Hose, ProFlex, Braided Stainless Steel, -10 AN, 10 ft. Length RUS-632170"
http://www.summitracing.com/parts/RUS-632170/
"1/2 in. NPT,5 3/4 in. x 11 in. x 1 1/2 in. fluid cooler B&M 70273"
http://www.summitracing.com/parts/BMM-70273/
Summit® Fluid Cooler Mounting Kitshttp://
www.summitracing.com/parts/SUM-G4990/
Reference:
zerothread/167442http://www.240sxforums.com/for....html
2) For GReddy oil cooler Adaptor, there are 2 set of -10AN inlet and outlet. So, there are -10AN to 1/8 NPT adapters (
http://www.240sxmotoring.com/1gaad.html) that I get buy for installing oil temp and pressure sending units. Is there an advantage of installing oil temp/pressure sending units on the GReddy adapter over installing installing oil temp/pressure sending units on NISsport Oil Pressure Adapter?
Turbo coolant lines:
Banjo Fitting Kit for coolant lines - 14mm Machined Alum to 1/4" NPT (QTY: 2)
http://www.atpturbo.com/Mercha...=GTBB
Fitting, 1/4" NPT Male to 5/16" Hose Barb (QTY: 2)http://www.compperformancegrou...tting
Goodyear Replacement Belts and Hoses 65127 5/16 in ID. Hose 25fthttp://
www.summitracing.com/parts/GTR-65127/
3) Is it true that I will just need to connect the two 5/16 in ID hose to the coolant inlet and outlet? Is there a way I can avoid bypassing the throttle body connection, and connect one hose to the throttle body and one hose to coolant line? That way the coolant will flow through both throttle body and turbo.
Reference:
http://www.sr20-forum.com/240s....htmlh ... com/ansize
Water temp Adaper:NISsport Water Temperature Adapter for 240SXhttp://
4) Is it ture that I will just need to install the NISsport Water Temperature Adapter in the upper hose of the radiator and install the water temperature sending unit on the adapter?White 7 Color Water Temperature Gaugehttp://www.glowshiftdirect.com....aspx
Reference:
http://pivotjp.com/product/ins....html
I am new to turboing car, so any comments/suggestions can be very helpful for me. I want to know every little parts that I need. Please let me know if you find any guides that is useful for KA24DET, and any alternative setups.
Thanks!
