http://cgi.ebay.com/ebaymotors....m245
After reading
http://forums.evolutionm.net/e....html
and
http://forums.maxima.org/super....html
, I think this setup might work better when under boost.
"Your method is not going to work well. The reason being is that your forgetting that our car has a maf. So any extra air comming in after the maf is going to cause drive-ability and or idling issues.
You have to do one of the following:
Keeping stock setup but running a catch can.
or
What I am doing, venting to atmosphere with intake manifold plugged and intake tube plugged to prevent outside air from getting in unmetered.
The breather filters might get some oil vapors because of oil vapors with the blow by gas. But you could get one of those catch cans that are not seald and have a breather on them. This would then have a place for some oil vapors to collect.
Remember the stock pcv line system is designed for emissions reasons while releiving the crank pressure. Since we all mod our cars, run no cats/hfc's, etc... We are breaking the rules anyways. So there is no point in keeping the factory routing. Also catch cans dont work 100% this is the only 100% true bone dry method of ensuring absolute Zero oil in the intake. With the assumptions everything is running properly." - by BluEVOIX
My new setup:
PCV valve -> oil catch can with breathervalve cover breather -> oil catch can with breather
Don't use the pre-turbo intake connection at all.
Pro
- No need to worry vacuum leak (unmeasured air goes after to MAF); good for tuning- When under boost, the PCV valve and valve cover breather can vent those air/oil to the oil catch can freely. The internal air pressure is much higher than the atmosphere pressure. PCV system works properly.
Con
- During idle/non-boost condition, the PCV valve will not have enough pressure to vent those air/oil to the oil catch can. PCV system doesn't work properly.
My previous setup:
PCV valve -> oil catch can -> one-way check valve -> pre-turbo intakeValve cover breather -> breather filter
Pro
-Under idle condition, the airflow from the pre-intake helps sucking those air/oil from PCV valve. PCV system works properly.
Con
-Under boost condition, alot of air will flow back to the motor through the pre-turbo intake, and the PCV valve and one-check valve will shut. The air/oil will be stuck inside the motor, so my PCV system doesn't work properly.
If we were just worrying about boost condition, new setup should work better, right?
