S13 KA24DE Timing
ArticDragon192
Car: 91 Z32 2+2
I know the stock timing should be set at 20° +/-2° but I wanted to know what would be best for performance. The +2° or the -2° and if I went that route if I would have to up my octane since I run 87 octane. Thanks for the info.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Knock it forward to ~22-23 BTDC ... and then you will need to use premium fuel.
Set the base timing with your TPS unplugged, idle at ~700rpm, warm motor...setting it without those conditions met and it'll be wrong.
- Brian
dickie
Car: Killer Turtle
correct me but shouldnt you be using 91 or higher octane anyways?
240DRFT
ya, use better gas
ArticDragon192
Car: 91 Z32 2+2
The KA runs just fine on 87 arco gas. No knocking at any point and running strong. Plus it's a stock KA so I don't see a need for running anythign higher and more expensive than 87. So basically anything over 20° would need better octane. K, i'll keep that in mind,
