KA13 »
https://forums.nicoclub.com/ka13-u37034.html
Tue Jul 18, 2006 6:31 pm
I did search for this but I didn't feel it was the same as the results and I was having some trouble trying to relate the information to my problem. I had a mechanic work on my car (replaced the head) and I think he screwed up the timing badly. When I finished the job he didn't finish #1 piston was at bdc. Today I ripped the valve cover off and turned the engine till the piston came to tdc threw it back on and tried starting the car. Then smoke started pouring out of the airfilter leading me to believe that I accidentally set it to exhaust valves open instead of intake. My questions are, Where is the mark located on the engine that you set with the notches on the crank pulley? and...Which notch on the crank pulley should be alligned with that mark?
