s13 KA24DE Stalling, flooding and running rich
nissan_s15_240sx
Car: '92 nissan 240sx with s15 silvia front end conversion
I was driving a few days back and everything was running fine, and as I pulled into a parking spot it bogged down and stalled. When I started it back up it was idling up and down, trying to stall, then after that it started idling high at 1000-1500 rpms. Exhaust smells rich and whenever I come to a stop and push the clutch it tries to stall, and if it does stall alot of times when I try to restart it the only way I can get it to fire up is to pull the injector plugs, and let it burn up the fuel. Anyone have any ideas as to what this might be caused by?
Grizeg
Car: 1992 Nissan 240sx SE Coupe
I would like to know also, my injectors are brand new, replaced in december, and my car is doing it to, it starting happening about 3 weeks ago, i still dont have a solution, and dont know what to replace yet, so this is a bump...
BUMPEDD
Now for the smilies
BTW im thinking its the fuel pressure regulator on mine.
Tech12
Car: 91 240sx Super Hicas
CHeck your tps, also, might be a bad maf or a vac leak. Good luck.
WDRacing
When you first try to start the car in the morning what does it do?
neverlift
it cranks up just fine why? lets go ahead and finish this thread.....
CTS ftmfl
see what I mean WD?
Tech12
carboard tube samurai?
neverlift
coolant temp. sensoror crack trickin slut that makes **** for gas economy and hard *** starts when warm due to flooding out that makes alot of noobs buy new injectors,fpr,o2,maf,plugs....
240sxmech
Car: 90 240sx
werd ..................they just wont listen will they
neverlift
yeah tell me no tell THEM all of them! wd is working on a noob faq for ka(snoozin on it for awhile)... wont matter IMO some will never learn like I neverlift lol
Tech12
neverlift wrote:coolant temp. sensoror crack trickin slut that makes **** for gas economy and hard *** starts when warm due to flooding out
I knew that... dammit
