tmillz422 »
https://forums.nicoclub.com/tmillz422-u213198.html
Mon Dec 10, 2012 6:44 pm
Hello i had just swapped in another engine and i have an overheating issue i`m stuck i replaced Thermostat, Water Pump,and Coolant Temp Sensor i have two electric blowing all in the right way, i also bled the system several times, the coolant and oil are clean and no smoke out of tail pipe doesn't seem to be Head Gasket, the radiator worked fine on the other engine so i don`t think its that and the weird part about it is that it only overheat when driving and ill let off gas it`ll cool down, i did notice the battery light came on so i when ahead an took a look at the alternator and the pulley was worn down really bad to pretty much nothing could be the pulley? i can also try flushing the system or possibly a new radiator cap. Hope someone can help its need greatly!
