lbs_ft »
https://forums.nicoclub.com/lbs-ft-u182870.html
Sun Apr 17, 2011 3:33 pm
I own a 1990 S13 Coupe that the had a 1993 KA24DE swapped in by a previous owner. I blew that motor, so I recently finished swapping in a 1996 KA24DE, and it started yesterday with no issues. I drove it around the block, not a problem, but I noticed that my radio wasn't working.
I pulled it out and began to check and replace all the connections, some of which bypass the radio plug and tap directly into the car's wiring harness, namely the ignition and ground wires. I had the key turned to ACC (f*** stupid, I know) which I fiddled with the radio so I would know as soon as I had it right, and it ended up being a loose ground connection, but I'm worried that I might have touched the ground and ignition wires on the harness together.
I got it all back together, radio works fine, then I turn the key, and the car cranks and cranks and cranks but won't catch. I pull a spark plug to see if its sparking. Nope. I pull the dizzy-to-coil wire. No spark.
I fiddle with the battery leads, and eventually when I try to turn the car over, the EGM relay begins to click rapidly. I replace it. No more clicking, but the car still won't catch.
So now I think I'm f***. There were no sparks, no smoke, no smell of burning electronics, but I'm terrified that I might have fried my ECU by leaving the key on ACC (stupidstupidstupid).
Anybody have any ideas? I'm in crisis mode now...
