S13 ka24DE intake resonator, safe to remove?
TheOne
Car: 93 240sx FB
hey, well the story goes as this, my stock S13(93) radiator died on it(it was bubling inside where the black plastic goes, and it had a small hole), well i just bought an S14(95) radiator(looks like a nice upgrade since its bigger), and well since its bigger it sticks further into the engine.now there's a what looks like intake resonator on the passanger side of the radiator, its an air box that only connects to the intake, no other inlet/outlet, and i guess it doesn't come in the S14's, it is in place with some screws attached to the lower fan shroud, and i was wondering, is it safe to take that out and not have idle issues or issues of other kind?, i could plug the part on the intake where the hose goes.(it doesn't matter if it makes the intake louder than normal).
KFL
Car: S14
S14s have it as well in the same spot. There is no harm in removing it just a bit louder intake. No need to plug up the other pipe air will still flow, no issues.
TheOne
Car: 93 240sx FB
k so its not necessary.......but i do have to plug the hole thats on the underside of the intake pipe right? cause i mean air can get in/out that is not metered by the MAF.
UPDATE: removed the intake resonator, and plugged the hole where it goes to the intake, car runs fine and doesn't overheat now with the 95 radiator, i still need to get the rad tight but its fine right now, doesn't move at all when driving.
Modified by TheOne™ at 7:45 PM 5/24/2005
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Yeah, it should be ok to remove
l3ooherS14
Car: 1995 Nissan 240sx S14
I took mine out on purpose. Its job is to silence the motor, so it will sound better if you take it out. I would get rid of it for shure.
sanioll
Car: Nissan 240SX SE
Toyota Camry
HERES A V8 MUSTANG SOUND.
REMOVE THAT THING, PUT A K&N AIR FILTER, AND CUT A BIG CIRCLE UNDER THE AIR BOX.
sTILL STOCK LOOK, BUT WAY BETTER PERFORMANCE AND SOUND. bEEN RUNNING LIKE THAT FOR FOUR YEARS.
artemous
Car: 95 240sx Ka24de. 81 datsun king cab. 9 corvairs
every car that has had an aftermarket intake or pop charger has removed the intake resonator. should actual free up a few hp and give you a cool sound although somewhat louder. Some people leave the resonator in place but drill larger (1") holes in the aircleaner box directly below the filter. Emphysis on below the filter.
wallybman
to make a cheap intake (did this on my old wrx, and a buddy's altima) i cut the whole lower half of the airbox out, leaving only a frame for the filter, and "legs" to bolt it down, that way the whole lower half is an intake, instead of a little 2 inch circle. works fine. sounds great.
