S13 KA24DE Engine Removal
yotik
Car: 240sx Hatch
weird240 wrote:i smell a stickey! def worth being one for all the first timmers!
+1
This is very straight forward for the newbies like myself. It probably saved me 2weeks of guesswork.
King Daffee
Car: 1992 Nissan 240sx
hey, where did you put the oil afterwards?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
LOL! That's funny 'cause I still have it! I need to take my drain pan in to be dumped and the rest of the fluids are in a couple of milk jugs in the storage closet. My first oil change will be coming up in awhile so I better get off my duff!
Firewind
Car: 240SX
Awesome post! This is going to help me out so much when I pull out my engine in a few weeks.
One questions though. I was hoping not to pull the transmission with it, since my transmission is fine, it's just my engine I am fixing. Is it possible to pull the engine with out the transmission?
del82
rcabrita wrote:Out the Bottom: If you have a car lift...Out the Top: If it is on jack stands...
Out the Bottom: If you have a lift and don't mind removing most of the undercarriage, and then possibly having to tackle body warping issues later since you removed important structural components from the car.Out the Top: if its on jack stands, or you're sane and don't enjoy doing a lot of unnecessary work
Fixed.
EDIT: Firewind: Yes, but it's actually easier to pull it *with* the trans, then take that off once its out of the car. Easy access to the bellhousing bolts, which can be a bear to get to.
Firewind
Car: 240SX
Thanks del82
positron1
Del's right, out the top is best and easiest. Getting to the transmission bolts(without a lift)with it still in the car would be a pain and I can't see how you would be able to stab the transmission in with it still bolted up. You have to be able to give it a little shimmy-sham when you stab it.
alwaysslideways
Car: 91 240sx s13 hatchback
read the write up and its great.
i had and am still having trouble with the driveshaft, but it'll work out. one problem im still having is when your disconnecting the harness completely, theres a connecter by the ECU covered in foam, WAAAAAAYYY up there in a crevice thats a bish to connect/disconnect. i swear, you have to have a 3 inch hand to do anything with it. ive managed to disconnect it, but cant connect it again. again, WHAT WERE THE ASAIN PEOPLE MAKING THE CAR THINKING????!
positron1
I know EXACTLY which connector you are talking about, I HATE that connector. It's almost impossible to disconnect, I spent like 15 minutes trying to take it off when I removed the KA and when I was wiring the SR I mistakenly connected it but had the ECU upside down and had to disconnect it again...took about 20 minutes of cussing and fussin'! What were they thinking on that one!
angrypenguin182
Car: 91' Nissan 240sx
Hey guys im fairly new to this forum, helped me when i had to replace my thermostat. I'm gonna be swapping out my ka(91), and dropping my brothers(95) in it. since they're both dohc, would I be able to use my wireharness to do i need to use his. Also if i can use mine, do i really need to completely take it out?
positron1
The S13 is OBD I where the S14's are OBDII so it won't work as far as I know....anyone else chime in on this!
angrypenguin182
yeah i know that difference only reason we're leading to believe it fits b/c the engine for the most part appears to be exact fit, but either way i could also take his ecu and use it in mine?
and also from what i've heard, the 95 was OBD I. apparently towards the end of the year they changed it to OBD II
B-Boy DuB-L
Car: 1993 Nissan 240SX
the engine is the same exact engine. Yes it should be OBD1. Considering they started making the 95 cars in 94 and OBD2 didnt come around until 96.
positron1
So all the MCS14's are OBDII.
B-Boy DuB-L
so whats an mc??
angrypenguin182
from what i know it's like part of the car code, it's on my vin number idk lol.but ok thanks guys hopefully within the next 2 months i can drop it in my car, because i spun a bearing inside my engine from pushing it too hard :/.
positron1
B-Boy DuB-L wrote:so whats an mc??
It stands for minor change(MC)....the MCS14's that got a facelift from the 95's.
Idahos13
Car: 93 240sx hatchback
If you want to use your harness then you have to change the dizzy because the s14s went to the internal coil, and you have to change the intake manifolds I belive it is the top part only, change the s14 exhaust manifold, and the vacume housing in the back of the head, but thats all I know about that if you want to use ur own s13 ecu and wiring harnes but thats only my 2cents
RustspecS13
Car: '74 260z and '88 300zx turbo
Firewind wrote:Awesome post! This is going to help me out so much when I pull out my engine in a few weeks.
I highly reccomend pulling them together. One time I pulled just my engine, and when I put it back in I snapped off the sleeve the TOB rides on. That lead to almost FUBARing my new clutch, and screwed up my oem TOB. Of course that ment I had to pull the engine AGAIN.
It may take a little longer, but really its just easy work. Putting the engine/transmission together is a B**** most of the time and like I said before can lead to broken parts.
~Alex
iiCiHiAiiViiPii
Car: 1990 240sx and 1995 240sx
sick write up!!!
s13_dk32506
Car: 1991 nissan 240sx
so i haven't been on in a while. mainly cus im 17 and i don't have a job to get money. its been a while since i tinkered with my 240 and im trying to put some stuff back together.
i have an auto transmission and i REALLY need some picks of how to put it back together or take it apart. anything will help. please i need this cus i seriously forgot what goes where. lol.
s13_dk32506
positron1
I don't have any experience whatsoever with the automatic transmissions...sorry man. Anyone else?
Kalypso
s13_dk32506 wrote:i have an auto transmission and i REALLY need some picks of how to put it back together or take it apart.
http://www.nicoclub.com/FSM/240sx/91-94/AT.pdf
240lookis
Car: 1990 240sx hatch
thanks for this man. super helpful in my process of removing my sohc
pungkiteater_671
thanks for the writeup i will be swaping my motor out pretty soon and will be using this fursuree !!
one question did you use air tools ??
Modified by pungkiteater_671 at 2:07 AM 9/30/2009
positron1
240lookis wrote:thanks for this man. super helpful in my process of removing my sohc
pungkiteater_671 wrote:thanks for the writeup i will be swaping my motor out pretty soon and will be using this fursuree !!one question did you use air tools ??
No just hand tools...that sounds perverse!
whyastarin
Super write up i am so glad someone took the time and took photos instead of jumping in hands first. This doc helped way more than my chiltons manual that i was using. Have to get the motor & transmission out for the 450sx swap.
combatninja
Car: 1992 240sx SE / 2008 Honda Civic coupe
Hey bro just got having an issue wondering if you could help me out. I have two fans instead of just the one your showing on the engine. I screwed up the fan shroud which is what holds the second fan in place so now I have to buy a new one. Not sure if the fan behind the radiator is necessary or not but I there's no way to pull it out without cutting the wires so I haven't worked on the car in like a week. Im currently trying to pull the motor, but im in the beggining proccess. Aside from that I also have two cables that connect to the throttle where you only removed one. Any advice you can offer would be greatly appreciated.
"Live fast, die young, leave a good looking corpse."
positron1
whyastarin wrote:Super write up i am so glad someone took the time and took photos instead of jumping in hands first. This doc helped way more than my chiltons manual that i was using. Have to get the motor & transmission out for the 450sx swap.
Thanks!
combatninja wrote:Hey bro just got having an issue wondering if you could help me out. I have two fans instead of just the one your showing on the engine. I screwed up the fan shroud which is what holds the second fan in place so now I have to buy a new one. Not sure if the fan behind the radiator is necessary or not but I there's no way to pull it out without cutting the wires so I haven't worked on the car in like a week. Im currently trying to pull the motor, but im in the beggining proccess. Aside from that I also have two cables that connect to the throttle where you only removed one. Any advice you can offer would be greatly appreciated.
Is this an automatic or a manual?
