S13 KA24DE A/C parts gathering... (searched)
ash_man
Hi guys. I searched for a topic for this, but turned up none. Hopefully this can be a first.
Basically, I took my 240 out to get its A/C checked at Goodyear and they said the compressor isn't working. Not only that, I have to replace the whole system. They wanted way more $$$ than I can afford or consider worth it ($1000+ for a whole new system, they don't do used )
What I need to know is what parts do I need to gather, since I rather have a perfectly working used system and have a pro to install it. Sure, it's not new, but for my 240 that's ok. Since my friend has an S14 with a working A/C, he's offering it to me since he's swapping out the engine.
So far, I know there's the compressor and the condenser. There are also other parts to the system, any ideas? I need to know the A/C parts that are in the engine bay, my cabin A/C are ok.
Also, are they any differences b/w S13 and S14 KA24DE's that might make the A/C systems different?
Thanks.
hugesack
Car: 89 240sx
they can't tell you the whole system much less anything is bad without first seeing the compressor working. before you go buying all kinds of parts, first check the a/c relay and fuse. if thats your first problem then go back to good year and kick the s/m in the balls
ash_man
Thanks, I'll make sure.
They did a diagnostic on the compressor when I brought it in and said the compressor won't pump and when they gave me an estimate, I just took my car and left.
To mention also, whenever I try turning on the A/C, it just blows uncooled air and the compressor makes this constant clicking noise all the time. The belts even make this squealing noise whenever I turning on the A/C also. My heater works fine. Anyone knows what this means?
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
There is a good chance the clutch in you compressor is bad. I fixed my AC after a bad repair job by AC 'professionals"....i paid almost $800.00 dollars for a one year of A/C....
The second time, I bought a new compressor on Ebay, a valve and dryer. 3 years later is running like a champ. You might have contamination in your system but a good flushing will take care of it. Then replace parts, fill with refrigerant and voila! Search the web/NICO for tips and basic A/C operation before troubleshooting.
