Ken Park »
https://forums.nicoclub.com/ken-park-u43991.html
Mon Feb 09, 2009 1:26 pm
I hope I dont look too redundant coming back to this thread to post, but I have made some good progress this afternoon. I found that the lower engine wiring harness connector wires do not match up to the grey plug on the fuse box. I jumped the wires (green/blue and green/white) from connector to connector, put the car in reverse with key on and BAM, reverse lights! Now I need help finding out as to why the wiring in each connector does not match up....Also, as I may have stated above, I got a new lower wiring harness----and some things seem to be different than the old one on the car. The old one is still in--there are old and new wiring harness connectors co-existing, because the battery is relocated to the back. The big white wire that goes from the alternator plug to the fuse box connector, is the same, but the small diameter white/red stripe wire on the new harness goes to the same connector as the transmission switches...? On the old harness, the small white/red wire is alongside the big white one coming from the alternator and plugs in at the same place on the connector at the fuse box. I know its confusing, but what Im saying is, the small white/red wire is not going to the same place as before, and that plug connector at the fuse box that the new trans. wiring harness connector plugs into sure as hell doesnt have a corresponding white/red wire for it. At this point I dont even know if my alterator is charging my battery. I have an Optima red top, and not getting a battery light on the dash. Seems as though when I first start the car, which has no trouble at all starting, the lights on my dash are just a tiny bit dimmer than normal, and then when I start driving they go to full bright.
Modified by Ken Park at 9:51 AM 2/11/2009
