300Plus »
https://forums.nicoclub.com/300plus-u30494.html
Mon Jun 16, 2008 6:57 am
Im trying to help a buddy finish a swap and need some wiring help. I'm stuck between just using buying an s14 upper motor harness and plugging it into the s13 motor (which from what I understand would require changing the distributor and maf) or using the s13 upper harness in the s14 and rewire where needed. the motor is out of his wreck 1991 s13 and going into a 1995 s14.
Has anyone done this before? the 6 main plugs at the engine bay fuse box and the interior harness plug on the s13 harness are different then the s14 so would need to be rewired. Any help would be great guys!
Ive been wondering if the 95 altima that has the KA in it, would have the same harness as the 95 s14, or atleas similar plugs to use.
