S13 KA Grounding!
DubsSuck
Car: s13 hatch
so my car hesitats like crazy on cold start ups, and i read that grounding that car a little bit better could help solve that problem. I was just wondering whats the best way to ground it without relocating the battery to the back? Pictures would help the best. thanks!
lbreevesii
Car: S13 hatch LeMons project - Kaputzen!
BMW E30
diy-grounding-kit-t216236.html
There's a guide for that. :-)
Check it with a multimeter before you do anything. Mine is perfect.
DubsSuck
Car: s13 hatch
So.. It really doesn't matter where you mount the wires? And you don't have to overlap them?
shiro_neko
check the resistance of your engine bay including the manifold and engine block. put your grounds where the resistance is high.
zerothread/159907
CTS13
Car: 91 240sx, 02 Camry, 09 Gsxr600
I have to do this on my bike cuz my bike has some hesitation going on.
DubsSuck
Car: s13 hatch
OK so i check the checked the resistance through out the engine bay while the car was off and it read a steady 16ohms all through out.. now its been a while since my electronics class so im a little rusty, but he multi meter was switched to the 50 so that prbably means it was at 160ohms. and now that i think of it i probably should have had the car running.
zachattack_5491
Car: Pignose S13 Redtop SR
Well that's pretty high. You want 0ohms.
shiro_neko
2ohms or lower. mine is at 4ohms at other parts but it runs fine.
car doesnt have to be running. check again. try checking the (-) terminal and the opposite end of the wire connected directly to it.
Klits562
Car: white s13 coupe
doesn't high resistance indicate a ground problem?
DubsSuck
Car: s13 hatch
yep thats why i purchased a grounding kit not sure when its going to get here because it coming from the UK and i had to buy it in GBP not USD
zachattack_5491
You should have at least tested it with some temporary wires before buying that. Just throwing parts at a hesitation problem is very expensive. There's a grip of problems that can cause hesitation.
