S13 ka cluster will fit into s14 ka ???????
JF240
HI,I finally find why my rpm dont work, its my cluster, the motor and the chip of the needle is broke. I would like to change only the needle and the module of the rpm. Only the part that is hold by 3 screw. Do you know if this part of an s13 will fit on a s14 not the cluster only this part. I would only install this part on my actual cluster.
