s13 just wont run right
TJR240hatch
Car: 91 240 hatchi rag
Hey guys and girls, I have a 91 240sx hatch se model. It has a 96 ka in it bone stock.
It will nto run quite right it will rev to the limiter if im easy on the gas but it will not rev past maybe 5k if i mash it.
Now driving is a totally different story it will barelys move over 3k rpms at any push of the throttle sometimes.
Now sometimes it will act fine then other times it wont. If i smash the gas it might pull hard to about 4k then it kinda goes in and out then bogs off until i let off. i have a new cap, rotor, plugs, wires, o2 sensor, fuel pump, and fuel lines, fuel filter.
all the things listed have been changed i am totally stumped guys please help me.
TJR240hatch
Nothing ? today i pulled the intake mani and check for vacuum leaks there are none. and everything looked fine used a new gasket for the lower half and the upper portion. it will rev to 4k and it starts crackiling and popping and isnt running right at all and has alot of the same issues ? anyone have any advice?
TJR240hatch
Ok just pulled my codes and there 43 E Throttle position sensor circuit 34 Detonation sensor circuit
I just replaced the knock sensor when i had the intake off and ive had the tps unhooked for acouple of months now and its been fine then just started aacting up??
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Did you remove the distributor? Also- has the car ever ran right? Worse after you put those parts on?
I had a problem where I installed the distributor a tooth off and it ran that way, it ran, but really crappy, it would only drive on light throttle, and buck and pop with medium to full throttle.. I had to reinstall it several time to get the tooth I was looking for.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
So you're driving around with the TPS unhooked? I'd fix that before you do anything else.
