s13 jdm cluster
turtle
i just got the car.. and it has a jdm cluster that reads im km.. i hate it.. i want a usdm one.. its a late model sr20det blacktop.. oboII.. wat other gauge clusters can i swap into it w/o any problems?
SpeedRacer1
Car: 1990 240SX, G35
There is no OBII in Japan. Are you absolutely sure its a Kouki Aug 96-98 engine? Are the needles amber?
If the needles are white you can just take the Speedo out of a USDM cluster and swap the two.
If it actually is the amber needle with charcoal gauges, then the kouki S13 SR uses the S14 speed sensor. So you could try a USDM S14 speedo gauge, but I cannot guarentee fitment, and it will look different. Also you will have to do your own custom wiring.
turtle
its not a amber needle. well say it is obdI wat cluster can i put in it?
RMiller
Car: BBQing
You can also make your jdm speedometer read in mi/hr. Check it out.
http://www.zeroyon.com/pics/in....html
SpeedRacer1
You actually have an "EARLY model blacktop S13 SR20DET."
What you do is you use the USDM cluster that came with your car, and swap the JDM tachometer into the USDM cluster.
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
Is there any place other than ebay where i can buy a s14 jdm gauge cluster for my S14.
turtle
all of this sounds so difficult.. i want something simple.. is there anything easier?? like a direct swap of gauge clusters?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
you can just swap tachs? so everything esle is USDM and the tach is JDM?
SpeedRacer1
turtle wrote:all of this sounds so difficult.. i want something simple.. is there anything easier?? like a direct swap of gauge clusters?
This is rediculous how lazy you are. This procedure only takes about 15 minutes for me to do. You can get the USDM 1991-1994 gauge cluster but then your redline on the tach will be marked incorrectly.
You going to switch the clusters out anyway, when its out, remove the 4 screws and swap clusters.
Heres an illustrated instruction..http://www.lsauto.com/install.asp
SpeedRacer1
D1SR240 wrote:you can just swap tachs? so everything esle is USDM and the tach is JDM?
Yes...
turtle
and how can u do this?
turtle
the instuctions u posted seem to complicated
SpeedRacer1
Then you probably shouldnt be touching cars.
BaliLover
I have to agree. If you can't do something that basic without a 50-step detailed instruction manual, then you don't have the basic mechanical ability it takes to work on cars properly.
Luke
You guys aren't very nice to an apparent novice. :-|
turtle: just take it apart, it's not that hard.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
SpeedRacer1 wrote:
Yes...
oh ok, thank you
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
turtle wrote:the instuctions u posted seem to complicated
Its pretty easy, you can figure it out.
IM not mechanic myself. I used to not do my own oil change, thats how dumb I am. But I figured it out eventually. Now, not only i can change my oil, i can change my suspension, brakes, etc.. as well.
robbbby
Sell me the cluster.
912.0turbo
Try going to lsautomotive's website and click on products. It shows you how to take it apart.
SpeedRacer1
912.0turbo wrote:Try going to lsautomotive's website and click on products. It shows you how to take it apart.
Read the thread. The link was already posted.
912.0turbo
I did read it. just missed it. Chill.
xTearsFallForeverx
Car: 1990 s13 Fastback
yah if you ever decide to do like indiglo gauges or anything of that sort you are going to have to remove your cluster. better figure it out now. took me 20 mins my first time. way easy.
