Was in the middle of this "build" and in all my research I couldn't find any good write ups on rear J30 Hub swaps, just comments that "yes J30 will work. bolt on and go. plug and play.". But it isn't, so I thought I'd make a detailed write up to help clear things up. This is a rough guide. You're application may differ. This is only my 2nd 240 so if you have any input I should edit let me know!
Let me start off by saying I am not familiar with the stock bolt size for the traction arms,. All of mine were aftermarket and came with this car when I got it. They were 17 and 19mm nuts/bolts.
My suspension is also on coilovers, and I believe I read somewhere that you need a strut with a different style hub mount than stock. The J30 Hubs have an extended large dowel pin like thing thats been bored out and tapped for a bolt, forgive me idk the technical term for it, but it slides into the strut eyelet which has a welded in washer on the backside which a bolt passes through to hold it all together. Also note when I installed new J30 bearings the hubs started to bend where the E-brake shoes mount/dust shield when trying to press the old bearings out. I was able to beat them back into shape and work but it was a pain so be careful!
THE J30 HUBS
YOU CAN USE THE 240 AXLE
and you should. The j30 axle is longer. and some j30 axles are not the same 6 lug bolt pattern to the diff. I am running a 95 6 bolt J30 differential in my application (because it has the 6 bolt output shafts which match my stock axles), and J30 rear hubs and Front J30 hubs, but theres already a detailed write up on those. Now I did notice one other thing, I bought these J30 rear hubs used and I read in other threads that you have to modify the lower ball joint mount by grinding it down, and it appears someone had already done this to mine, it didn't seem like they had to grind much but idk what they look like stock so
THE PROBLEM
The backspacing on the axle to the hub difference between the models means that the stock s13 axles dust shield will be pressed into the rear hub bearing seal on the J30s hub. The seal is a friction fit so its stationary, while the axle needs to spin. Everything feels fine upon instal but you will quickly discover when you tighten the axle nuts suddenly the entire rear locks up like its in a bind!
Here is one off the axle to show
Which the solution is easy. Just lightly tap the shield off with a hammer.
ITS THAT EASY.
The new Fitment
VIDEO LINK BELOW
https://flic.kr/p/2a4484d
THE NEW PROBLEM
I used B13 Sentra '89 front ball joints on my rear suspension arms but it seems the J30s ball joint hole tapers at a greater amount than the Sentra one does, so theres some play, im talking 1mm or less in diameter. Has anyone ran those on this setup?
Stay Tuned.
