S13 intermittent battery drain
Nis-240sx-san
Car: 1991 Nissan 240SX KA-T
Hello All! I've done some researching, but could not seem to find direct information regarding my car's issue. What has just recently started happening is that my battery will drain overnight. It all started a week ago when I was leaving class. Class ran from 8am-2pm, and my car started and drove great to school. Leaving class however, my voltage was at 9.8, and the starter just clicked. I had a friend jump my battery, and the car started no problem. I didnt have an issue with it until a week later. I went to start my car and nothing turned on. My Volt meter on my safc read 7.5, and then everything shut off. I then hooked in a test light between the negative terminal of the battery and it is lit up, so there is some parasitic battery draw. I proceeded to pull all of my interior fuses, and the light did not shut off. So i moved to the engine bay fuse box and started there. I've read that some people had issues with the FL75A Alt fuselink, and when i pulled that fuse, the light went out. But i continued pulling fuses and noticed that when I pulled the FL25A RET MTR fuselink, it dimmed the test light. And now im stuck here. I know the FL25A RET MTR fuselink dims my test light, and the FL75A ALT fuselink turns off the light all together. I took a second look at my battery too. I noticed that it looks like it could be leaking around the 2 caps ontop, but no fluid draining down the sides of the battery. There is also no corrosion aorund the terminals, and they are/were tight. I should also mention that my battery is relocated to the back of the car, and i have wood under the batter to elevate it away form the metal in the back. I'm going to start by replacing these fuses, but where else should I go from here? I've never been a fan of electrical issues, but since this is my daily, i really need to fix it asap. any advice is greatly appreciated!
Hoffman5982
Car: '95 sr20det 240sx
Have you taken the car to autozone and had them test the battery and alternator?
slayer6o6
Car: 1989 Blacktop 240SX SE
Your going to have a parasitic pull from a couple of devices in the car, such as the clock. I would do as hoffman says and have the alt and the battery tested jic... it could possible be a dead diode pack in your alt that is not fully charging your battery.
polk240sx
Car: 1997 240sx kouki
1992 240sx HB project
how do you have you battery held down?
truckmtr240
Car: 91 240sx hatch
my trunk light always stayed on after I put a new hatch on. drained my bat. Check lights and stuff that draws such as stereo
zuoluomi
Car: url=http://www.jerseysera.com]Jerseys outlet[/url]
[url=http://www.jerseysera.com]Jerseys Basketball[/url]
If a moncler outlet speaker looksQuite the contrary. Jerseys outletat you continuously when speaking, as if he tries to dominate you, you Jerseys Basketballwill feel the eye is a moncler jackets sign of honestcommunicationdisconcerted. A poor liar Jerseys Footballlooking too long at the victim, sincemoncler clothing he believes in the false idea that toJerseys clothinglook straight in the eye is a signmoncler online of usually exposes himself by signature
Hoffman5982
LOLWUT? ^^^
MODS- maybe you should require CAPTCHAs when creating an account. Ive seen a few of these spam profiles popping up with completely random things, but none as random as this guy
Brent.S13
Car: 1995 Coupe- Totaled
1991 Hatch- Current
Lol is that like something we gotta translate? Did anyone get that?
s13_chris
Car: 90 240sx Hatch
Read it without the links. First sentenced is messed up. Talking about people and eye contact in relation to their truthfullness!
