1990 S-13 Original Owner
I had to replace my speedometer because it was always reading 45MPH. I bought a cluster replaced the speedo, no problems everything works great. I did notice that 2 bulbs in the dash were not working so I just lived with it. Today I decided to look into the blown bulbs. Took it apart and they were not turned all the way in not making a good connection, I fixed that and got every light working fine. I had the ignition on and also the headlights to test all bulbs, PERFECT. Well IDIOT me sat the cluster on the column (not covered) and I heard a bad low electrical sound and ALL the bulbs went off. The only working bulbs are the little red lights only on the right side of the cluster when the key is turned. The ones on the left side do not light up now. I WAS SO MAD AT MYSELF & wanted to throw the cluster in the air! It always happens to me because I am in a hurry & do not think!
I started to check all the fuses on the right bank of the fuse box and all good, it started to rain so I stopped because of rain and also because I was so mad.
Now when I turned off my alarm the instrument panel gauge lamps lit up 2 times with the sound of the alarm making 2 chirps and then goes dark, it blinks on and off when I set the alarm or turn it off. But when I turn on the ignition on and the lights on the left side small lights do not light up and all the dash lights do not light up with the headlights on. The AC Panel also does not light up now that I screwed it up!
I thought I blew the bulbs but now I now know the bulbs are good but have no Idea what to do. The dash will light up only when the alarm is turned on or off & the alarm works fine.
Did I mess up the Cluster when the back touched the metal on the column? The noise sounded like a fuse blowing but I did not see a bad fuse, I only checked the right side of the inside fuse box because it got dark
I can live without the red lights on the bottom left (low gas, windshield fluid,ETC) I just want my dash lights and AC panel to light up.
I do not remember if the Dash lights came on when I set my Alpine alarm before. I have had that alarm for 12 years and forgot. I do have the alarm set to make the driving lights flash if it goes off and those to go on and off when I set the alarm.
PLEASE ANY SUGGESTIONS
The dimmer was not connected when I messed up the cluster. None of the switches, buttons were plugged in at that time.
Maybe I can just run a 12 volt wire to the back of the cluster but I have no Idea where to connect it or if that is a good idea..
THANKS
