s13 in Autocad?
nismostate
Car: all sorts of motorsports
Does any one have the s13 detailed in Autocad? My friend found one for his 1st gen eclipse gsx and I was wondering if there was one for our car. Everything on there is in exact measurement. with all this info you can pretty much make anything for your car. (ex. intercooler piping, cf hood, etc.)
burnin240sx
i have a 3d max model that i could export to dxf format but it's just the exterior of the car. not sure if that's what your looking for.
nismostate
that would be fine! I might be able to use that to make a cf hood. well are the dimensions acurate?
erich
If you could shoot that over to me as well that would be awesome.
burnin240sx
well how about i host it. here's the linkhttp://burnin.no-ip.com/share/240sx_Stock.rar
i'm not the best at 3d. but i'm sure it's better then nothing.it's not set to any measurements but i'm sure you can check and scale it i think it's preaty acurate.I got board and uesed it to make this http://burnin.no-ip.com/share/car.jpg
Ligouri Rd
Car: '96 Nissan 240SX
Any chance that you could post an .iges of that file?
Also while we are on the topic, does anyone out there have a 3d model of an S-14 (preferably Zenki, 95-96)?
burnin240sx
Ligouri Rd wrote:Any chance that you could post an .iges of that file?
sure here u gohttp://burnin.no-ip.com/share/s13.igs
Ligouri Rd
Thanx for the file, but i got the error message upon opening it: "File was truncated or contains invalid data". Could you try to re-save it and post it again? Thanx
burnin240sx
Ligouri Rd wrote:Thanx for the file, but i got the error message upon opening it: "File was truncated or contains invalid data". Could you try to re-save it and post it again? Thanx
3D MAX probley did a bad job of exporting. it happenes nit much i can do. maybe you can find a dxf to ige converter. that might be a better option.
Ligouri Rd
Quote »maybe you can find a dxf to ige converter[/quote]I can try that, I think I already have a converter. Where did you post the .dxf version, I only see a .rar format?
burnin240sx
Ligouri Rd wrote:I can try that, I think I already have a converter. Where did you post the .dxf version, I only see a .rar format?
rar is a compressed file of many files and it has the dxf and maps i used in that rar.
Ligouri Rd
What program did you use to decompress to get the .dxf out. Currently I have Autocad (2001i) and Solidworks.
burnin240sx
i used winrar. found at http://www.rarlab.com/
