SR24DET »
https://forums.nicoclub.com/sr24det-u65780.html
Sun Mar 22, 2009 12:11 pm
You guys can't know whats wrong just yet. Theres so many more questions.
1. You said there was a puddle under your car, where is it leaking from. Put fluid back in the cylinder, Have a friend press down the pedal, and watch where its leaking from. It has to leak from some where. Where it leaks from is where your problem is.
2. You said the pedal went down but not back up. You said you added fluid in but it still wouldnt come back up. Well, there could still be air in the line. Especially if you still have your clutch dampener installed. That things F**ks everyone up.
If the pedal goes down but doesnt come back up it could be...clutch masterclutch slaveLeak in the lineclutch dampeneror the actual clutch itself.
so to sum it up..
Sence you had a puddel underneath your car you need to find where it leaked out from and thats where your poblem is.
Sorry for the long post, theres just so much to cover, and theres so much more I could add to this..
