s13 hud issue, wont always work
lizmo
Car: 93 coupe, 91 hatch
1989 240sx coupe
5spd
HUD.
stock it has a Kenwood cd player in it (previous owner installed it)
the HUD seems to come and go out every so often. if you tap on the dash sometimes it comes back, other times it stays out.
all the other lights work (HVAC,Glovebox,taillights) is it the capacitor that most HUD's have that go bad? it's just odd it's not always off.
any help?
biggie
Normal issue, search for HUD repair, its usually the HUD eletronic board that needs repair. But most just buy another cluster to replace it.
supersayianjim
Car: 89 240sx(s13)
i had the same issue. i actually changed my cluster and hud unit. cut the wires by accident,so i had to solder them(and i can't solder for s***) but i got it done and it didn't work until i pulled my engine and reinstalled it. now it comes on when the car heats up. so ya change your unit but you don't have to swap the dash(finding an uncracked hud dash in the junkyard nowadays is like impossible..
lizmo
biggie wrote:Normal issue, search for HUD repair, its usually the HUD eletronic board that needs repair. But most just buy another cluster to replace it.
Cool, thanks i looked at that last night...i just assumed that issue was if it was always off. no big deal i'll look into it. thanks.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
The typical repair is replacing/resoldering a couple of diodes.
sandcrabsailor
Car: 1993 240sx SE HB
Or get ahold of broadfield. He's done some amazing HUD work.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Caps and diodes..... easy fix
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
order repair parts from newark.com
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
Thanks guy's for the help.
i know we took the gauge cluster out a little bit. looked at the wiring, took the cluster apart. and played with the circuit board a little bit. everything "LOOKED" ok. we noticed if you touched the 2 circuit boards the lights would go out. then if you let go they worked.
we had a friend who does electrical board's for a living he touched the sodors up and still the same issue...
