nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Tue Jun 27, 2006 12:52 pm
are you looking swap a HUD for an analog or for a newer HUD?
If you are just trying to change the tach you will need to do a bit of trimming to get the tach face plate to fit the older unit properly. Also when I did this swap my newer tach needle had to be swapped and the newer tach was too big for the cluster so I just changed the electronics to the older tach.
