s13 hood wont open
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
alright so my hood wont openi think the wire that is connected to the hood latch is not connected to the latch anymore and i cant figure out a way to get my hood open.
anyone had this problem before?what did you do?
JStrateger
Car: 1992 Nissan 240SX
Yeah, my latch spring was rusted though. I had my brother hold the open switch from withing the car and I pushed on the hood a couple times until it popped.
After we got it open I sprayed with with 10-30 and it fixed my problem.
If your cable is broken you'll beable to tell from your very easy to pull interior switch.
240sxvaj
JStrateger wrote:Yeah, my latch spring was rusted though. I had my brother hold the open switch from withing the car and I pushed on the hood a couple times until it popped.
i dont think my wire is broken, im sure it just came loose because it did before and i put it back on but when that happen i was replaceing both of my headlights so it was easier
do you think i can jack up the car and pull the latch switch from there on?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
240sxvaj wrote:alright so my hood wont openi think the wire that is connected to the hood latch is not connected to the latch anymore and i cant figure out a way to get my hood open.
Yeah, I was able to reach up from under the bumper with a 10mm socket and remove two of the three bolts from the hood latch and get it open. Turned out to be that the cable had popped out of the latch.
240sxvaj
positronone wrote:Yeah, I was able to reach up from under the bumper with a 10mm socket and remove two of the three bolts from the hood latch and get it open. Turned out to be that the cable had popped out of the latch.
yup same thing happen to methanks for the help
