Postby
s14_drifter8 »
https://forums.nicoclub.com/s14-drifter8-u18379.htmlTue Feb 20, 2007 6:11 pm
Ok so there was snow on the road. I was gong to school one night and the roads were slippery. As I approached the school driveway i slowed down but the car didn't respond. What happened next was like watching a horror movie. The car slid right towards a curb. All I can do was watch as my S13 hit that curb. BOOOM . So now the front passenger wheel looks like it's been moved back towards the rear wheel --> (0 )
I know the lower control arm is bent but is there a chance that the torsion bar's bushing maybe busted from the impact?
One more question: is the lower ball joint built into the control arm or is it replacable? Cuz my driver side wheel has a lot of movement from the ball joint. I can actually move the wheel in and out about an inch
I'm a noob when it comes to suspension work. If I can get some help here I will do a write up on the process.
Postby
s14_drifter8 »
https://forums.nicoclub.com/s14-drifter8-u18379.htmlWed Feb 21, 2007 3:16 am
redtop91 wrote:If your tire begins to wear because of rubbing against the wheel well it is only the control arm. Does it pull hard to that side when you brake?
Postby
homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.htmlThu Feb 22, 2007 7:04 pm
I wold take the wheel off and inspect everything like whiterps13 said and post some pics if you still have questions. That's the best way to tell what's messed up.
