Thanks,
Josh
Correct, I'm just looking for what that plastic bracket used to look like via a diagram or picture someone has handy. I might give Nissan a call today, they might be able to shine some light on the situation.amc49 wrote: ↑Wed Jan 24, 2018 10:54 pmSomething there is missing, the cable outer should be pinned in some way to your bracket plate with the bolt and the bolt needs to be tight with the bracket up to line the cable up with the lever the inside attaches to. End of cable simply has eyelet go over the pin but without a pinch bracket to lock the outer cable in place the end will fall off with any use. The slot in your bracket is likely to hold whatever clip or locking fastener that is missing there.
