Chris000000 »
https://forums.nicoclub.com/chris000000-u148588.html
Sat Nov 28, 2009 5:42 pm
well i just came across this problem tonight, i was messing around trying to do the "sleepy eye" BS and i wasn't really paying attention and grounded a wire i shouldn't have, now my headlights won't go up or down unless i do it manually, doing this trick messes with the headlight timer, that is what i grounded and i am going to check this first, so you may want to try checking the Headlight Timer, and where it's located is to the left of where your clutch pedal should be(kick panel), give it a shot, and tell me if it works.
